Sony theme engine
Not applicable
Sony theme engine
Do any versions of the xperia play have oem sony themes engine?  Looking here at this screenshot:
http://hp-gsm.blogspot.com/2011/10/sony-ericsson-xperia-play-tips-and.html
shows it insalled.
How do i get it is it a part of the bravia engine?  I have the AT&T phone so i know i can flash other firmwares except verizon so was wondering if it was on the i firmware or whatnot...
if the update it's not available and you don't want to wait for AT&T to release it, you can manually update your phone
http://talk.sonyericsson.com/message/108961#108961
14 REPLIES 14
are you referring to the first picture?
Not applicable
sorry no you have to scroll down then click on sony bravia engine installation
that will show you the screen shot.
oh ok, I see what you are saying, quick question
go to camera do you have the option to take 3D weep panorama pictures?/
http://www.sonyericsson.com/cws/products/mobilephones/overview/xperia-play?cc=gb&lc=en#view=features...
Scenes that pop out of the screen. In 3D
Straddle the peaks. Dive into the depths. Make your breathtaking mountain panoramas look, well, breathtaking. Select Sony’s 3D Sweep Panorama and catch the scene. Now amaze your mates and show it on a 3D TV.
3D sweep panorama
Take your pictures with 3D Sweep Panorama. View them on a 3D TV or on the multi-angle 3D display.
Not applicable
umm Hmm no i do not have that option.
Why do i not have that option?  Is this the reason why i dont have the theme option?
Sure would like to have these options.
go to settings -> about phone -> android version and build number
Not applicable
2.3.3
3.0.1.B.2.270
you are TWO updates behind
Xperia Play 2.3.4 latest Update 4.0.1.A.0.283
go to settings -> about phone -> software update
or use either PC Companion or Update Service to see if there's an update for your phone
Make sure you backup everything using the Backup & Restore app
if you need the app you can use this link instead to download the apk
http://www.megaupload.com/?d=I5CJUPJV
How to install it
You need to
go to settings -> applications -> check unknown sources
download IO File Manager
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
just to play it safe sync your contacts w/ google if you haven't already
open your phonebook
press MENU button -> tap on Send Contacts -> select all -> send it to your email
on your computer
-> download the file -> go to your gmail -> click on contacts -> click on more actions -> on the drop down menu click on "import" -> choose the file -> and click import
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
market my library.JPGmarket my library 02.JPGmarket my library 03.JPGmarket my library 04.JPG
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Logs
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
