Hi guys, I've had my arc for a while now, its running android 2.3.4 but recently the vibrate for notifications has stopped working.
The vibrate works when the phone is set to vibrate but when i add volume the vibrate goes away.
in settings under sounds I have vibrate as "always"
in the messaging settings i have "notification vibration" on also.
Im very confused by how this could have happened to me when it was working just days ago weeks after I updated the latest version of android.
thanks for any help you can give me!
did you tried the obvious turn off/on your phone?
how about
settings -> privacy -> settings reset
open the messaging app -> press MENU -> settings -> check vibration notification
also do you have another app running like handcent sms, or sms go?
I had lightflow to change my notification lights and vibrates but when i realized the vibrate wasnt working i uninstalled it but even after I took it off the vibrate/ volume combination has not worked
btw go to settings -> about phone
which
android version
and
build number do you have
2.3.4
4.0.2.A.0.42
i'm gonna try the settings reset
the settings reset worked! thank you
do you have any idea why i couldnt fix the problem without doing the reset?
does it mean that i shouldnt download lightflow again? its really useful
for future reference
Make sure you backup everything
and don't forget to mark the correct and useful answers
Settings -> privacy -> Back up my data and Automatic restore should be selected
and also
Use one of these links to download the
Backup & Restore app
http://forum.xda-developers.com/showthread.php?t=1193802
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
http://www.mediafire.com/?1n07llajeaoo03y
How to install it
You need to
go to settings -> applications -> check unknown sources
download IO File Manager
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
just to play it safe sync your contacts w/ google if you haven't already
open your phonebook
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Logs
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
