- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I guess this is directed to Sony support staff on this forum.
I'm running a new Bravia KDL-46HX923 with the 17/06/2011 PKG3.235EUA firmware release. Attempts to join a hidden wireless network (ie: one where the SSID is not broadcast) by doing a scan and entering the SSID manually result in an inability to connect to the wireless network.
Changing the router configuration to broadcast an SSID, then selecting the network from the visible list (using the same password) results in a wireless connection succeeding.
Once a connection has been made, any attempt to 're-hide' the SSID (ie: stop broadcasting it) results in network connectivity being lost.
I would appreciate it if you could please report this issue to those responsible for firmware development, with a view to enabling a fix in a future firmware release. Failing that, feel free to PM me any contact details and I'll attempt to provide the engineers additional information via internal email (I work for SCEE).
Regards,
Dean
p.s. Other people with 2011 Bravia sets are also reporting the same problem. For example, take this guy in Australia with a CX520 - http://forums.whirlpool.net.au/archive/1674885. Also, see reviews of the HX820 on Amazon.com at http://www.amazon.com/Sony-BRAVIA-KDL55HX820-55-Inch-Built/product-reviews/B004QXFI04 (the review from 'G.Cacciatore').
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Just bought the Bravia KDL26EX320
Update firmware to PKG3.235
Router is a Draytek Vigor 2820
Manually set up
Turn off Hidden SSID and it connects
Hide the SSID and the signal drops immediately and it won't reconnect until you unhide the SSID
So, not fixed yet
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Just bought the 32" CX523, and ran into this problem of the wireless connection only working if the SSID was set to broadcast. I wasn't very happy about that, but then I found the firmware update on the Sony site which took the TV to version PKG3.309
This seems to have solved the problem. It took a couple of attempts to connect the first time with SSID broadcast switched off, but it does seem to be working OK now (so far!)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yep, I can confirm my 22EX320 is working with SSID hidden. Looks like the bug is fixed.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I bought a 26EX320 last Saturday the 6'of august, i use the latest firmware, But still I need to broadcast the ssid when I stop the broadcast the connection fail.
I use a Siemens Gigaset SX 762.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Just to be sure, can you check if your firmware is PKG3.309EUA?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Am running latest firmware, and had to re-enter all my network settings again, but can confirm it's now working.
Dean
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Although it's 6 yr later, I may be in the same situation with a 4K 49" Bravia locking up my Airport network, once I tried to network things. I've had enough tonight, but can someone from Sony respond how I can have my network return to its previous working conditions? I haven't yet made any negative posts on Social Media.
Tony Anstatt
- « Previous
- 1
- 2
- Next »
