Press the HOME button, then select
[Settings].
Select
[System Settings] → [General Set-up] → [Factory Settings] → [Yes] → [Yes].
After completing this process, the initial set-up screen is displayed.
Hi
I am trying to update my kdl 502828b and need to do a factory reset.
The anual says I should hold the up button on the remote and press the power button *on the tv*
But the thing is, there are no physical buttons on my tv.
Is there any other way to do a complete factory reset?
Hi there
There are physical buttons on your TV. See:
http://pdf.crse.com/manuals/14HE468111/EN/c_t_side.html
However, you can factory reset this way too:
Press the HOME button, then select [Settings].
Select [System Settings] → [General Set-up] → [Factory Settings] → [Yes] → [Yes].
