Will this model support two single rank 4gb modules for a total of 8gb or do I need to use dual rank sticks like the original 4gb stock module?
Thanks.
Look inside the memory compartment - there are probably 2 slots. If so you just need to add a compatible 4GB module.
If there is only 1 slot, you will need to remove the pre-installed 4GB module and replace it with a new 8GB module.
https://uk.crucial.com/compatible-upgrade-for/sony/vaio-sve1512b1e
DDR3 PC3-12800 • CL=11 • Unbuffered • NON-ECC • DDR3-1600 • 1.35V •
or
DDR3 PC3-12800 • CL=11 • Unbuffered • NON-ECC • DDR3-1600 • 1.35V • 1024Meg x 64 •
