More of his media
Hello
I do not understand why but I no longer have the sound coming from the media applications or the system. Yet my speaker works, it is just the software that seems to think that it does not work then if. I do not understand..
Plus de son média
Bonjour
Je ne comprend pas pourquoi mais je n'ai plus le son venant des applications médias ou encore du système. Pourtant mon haut parleur fonctionne, il s'agit juste du logiciel qui a l'air de penser que celui ci ne fonctionne plus alors que si. Je ne comprends pas..
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
are you referring to
settings > sound > advanced ?
