RIght Pasword dosen't unlock the my celphone
ClaudiaColussi
Whene i Try to unlock my pasword via Patterns the screens go black and return to the blocked screen.
The pasword is right.  If i try to add anotherone it says that is wrong. The problem just occures with the right one.
I Tryed to unlock my cellphone using my thingers it works.
I tryed to  go to the configs to turn off the patterns but whene i try  to do so it asks me to conirm my pattern, if i do so it frezzes the screen or give me a the app stop working error.
What can i do??
2 REPLIES 2
Uliwooly
@ClaudiaColussi
That's quite odd, the first thing you could try is to restart the phone, if that doesn't work then boot in >>> safe mode and see if you experience the same issue.
Martin1
Enthusiast
Hi @ClaudiaColussi, and welcome to the support forum!
As @uliwooly mentioned it is a rather odd behaviour. Try safe mode and see if you are able to change/turn off the pattern there. If that does not work, I believe that the best thing to do is to repair the software using Xperia Companion and a computer. Keep in mind though that a software repair will also erase all user data from the phone, so it is advised to do a backup before the repair to avoid data loss.
Let me know how it goes!
