Ajb007
Safe mode
My sony xperia won't come out of safe mode so lost all apps.
Please help
1 REPLY 1
Jonas
Master
Hi @Ajb007, welcome to our forum!
If you don't get out of safe mode after performing a normal restart, make sure that the volume down button is not pressed down during the start-up as this will result in the device booting up in safe mode.
If you have a case on the device, remove it and see if that helps and you can also test if the volume down button works as it should in safe mode.
Let me know if that helps! Slightly_smiling_Face
