Телефон работает исправно, кроме звука. Он исчез внезапно, звук есть только если приложить к уху, то есть когда срабатывает сенсер и затемнение экрана, а сам звук не работает. Предложите что сделать в ремонт сдавать времени нет т. К телефон нужен каждый день обязательно,и скорее всего нужно скачать приложение саунд эбаут но оно после обновления перестало работать
The phone is working properly, except for sound. It disappeared suddenly, there is sound only if applied to the ear, that is, when the sensor and the screen are darkened, and the sound itself does not work. Suggest that there is no time to do the repair. There’s a need for a phone every day, and most likely you need to download the sound about application, but it has stopped working after the update
-GT
Hi @Alina5, let me see if I can help out here!
Your post has been translated to English as this is an International forum, please post any replies in English and it will be easier for me and other users to assist you.
Have you been able to carry out a quick test of the loudspeaker to see if the hardware works as intended? In order to do this, find and tap Settings > Support > Speakers and microphone.
Another thing that you can try is to reboot your phone in safe mode to see if the loudspeaker works better there. All apps downloaded from Play Store is temporarily deactivated while in safe mode and by doing this, you can see if this behaviour is caused by a downloaded app. For more information on safe mode and how to use it, click here.
If the loudspeaker behaves the same way in safe mode, I would suggest that you try to repair the software on the phone, as there is no setting for this. Keep in mind though that a software repair will erase all user data from the phone, so make sure to do a backup before the repair.
Try these measures and let me know how it goes!
