Hi all,
I have a question of which cable to use with my UCH12 MediaTek Pump Express Plus 2.0 pump charging feature.
The seller included the wrong cable, a Sony EC 803 which is a Micro USB and I need Type C (I already ordered the right one, the UCB20 and I'm waiting for it).
Can PE+ 2.0 work if I use a Micro USB to Type C adapter with the EC 803?
Also I have a couple other Type C cables but I don't know if they will work and I don't fell like doing trial and error.
After some research, in order for the USB TypeC cable to work with PE+ 2.0 I found that the cable should support a 3 Amp pass-thru charge.
Is that correct?
Also is there any way to identify the USB Type C cables that will work with quick charge in these type of chargers?
Thank you!
