Does the XA support VOLTE? The whitepaper on Sony Mobile's site states that the device does. But I am on T-Mobile US network and calls drop to UMTS/HSPA(3G). Sony support says the device does support VOLTE and I need to talk to carrier. Carrier says if the device supports VOLTE it should work. Nobody is giving good support. Does anyone know?
The build.prop of this device shows ims & volte disabled. This is not controlled by the carrier. This is controlled by Sony. I can enable volte via build.prop and I now see mobile networks settings. It is listed as "Enable VoLTE". VOLTE still does not work. When I enable ims in build.prop the device hangs on boot(Correction no boot hang). To me this seems as though the ROM has incomplete VOLTE & IMS support which a lot of VOLTE providers use. Is there a known instance where a F3113 ROM has working VOLTE on any network in the whole world?
Update: Just tried an AT&T sim in the device. Same issue. VOLTE does not work.
have you tried to contact your network service provider if it is supported on their network? this is mostly a network service
