100% sure touchscreen problem is hardware just look at this
Lxrg
12 REPLIES 12
profile.country.RO.title
_alexdon_
So you cannot unlock your phone?
alexdon
Lxrg
Not with a case on it or in a table or in bed or over a magazine or what ever
only holding it with my hands 90% of the time .
Allready in warranty.
_alexdon_
Well,it is a known problem with Xperia SP also,on flat surface the phone does not respond to touch.
alexdon
Lxrg
Happens in my hands with a case also. Not only in flat surface and as u can see in the video. If i touch metal frame it it doesnt have any problems
Lxrg
Most of the time.......
_alexdon_
This could be hardware problem,maybe a certain lot of phones has that problem.But it looks like software also,it is bad optimisation I guess.
alexdon
Lxrg
Mine is c6096 everything perfect only that terrible issue white one had first firmware installed, pretty sure is static or grounding issue result of glass and aluminum combo
_alexdon_
Have you updated to 4.3?Maybe it will fix it.
alexdon
Lxrg
Updated, to 257 still there. Flashed 4.3 same restored same re instaled 257 same
