Xperia S problem with transfering files from PC
KnifePartyyy
Hello everyone.. I have problem with my Xperia S.. when I try to copy files from PC with File Manager, it can't copy files.. it start copying and than it fails... What can I do ? When i was on 4.0.4 anroid i could transfer files, but now I'm on 4.1 version and I can't
7 REPLIES 7
KnifePartyyy
Anyone ?
KnifePartyyy
I tried to enable USB Debugging, but no results..
F**k.. i'm realy disappointed, no Mass Storage mode... that's realy bad..
Does anyone here has any suggestions ? Face_with_open_Mouth
Sam
Legend
Legend
Do you get a specific error message during the transfer?
What are your thoughts about this forum? Let us know by doing this short survey.
montu_007
Hii, I have same problem, when I copying files xperia to PC, its show... calculating the time required to copy the files... and then nothing happens.... I attached screenshot also...1111.JPG
lynn_hm
Hi, I think I'm dealing with the same problem as yours now.
I just upgrade my Xperia S to 4.1.2 (6.2.B.1.96). Then I found out that I can't copy files more than 300MB to it!!!!!!
When I copy a video file from my PC to the internal storage, it started normally but would be hung at the last 10 seconds.
There was a prompt window said "Canno copy XXXXXXX- The device has either stopped responding or has been disconnected."
So it just basiclly "disabled" the vedio play function.
Did someone solve this problem before?
Any suggestion here?
Sam
Legend
Legend
What format are the video files in?
Don't forget to mark posts that answers the topic as Accepted Solution.
If you find any post helpful, press Kudos.
profile.country.RO.title
_alexdon_
Normally,there is a 2GB limit on Android.Could it be a different video file,one not compatible with the phone?But still it should copy the file.
alexdon
