I own a Xperia Z for half a year now...no problems with it or anything....yesthrday I was eating at a restaurant there was a bolw of soup....I dropped my phone into the bolw when I was using it......It could't turn on...after a day which is today...it booted up and everything works fine...but after 2 hours my phone's volume up keeps going up...like it is being pressed or something....then after another 1 hour it turned off and keep binding and vibratingwhen I try to change it. It does not turn on when i press the start button, I tried pressing the power button and the volume up keys together for 8 sec too but it still does not work....also the changing port thingy is red...
Hi there,
Dry your phone best you can!
Then press and hold Power button + Volume Up for 8 second(same time).
Then charge your phone about 1 hrs and then try to power on.
Cheers.
.....Second solution - Take your phone to a Sony´s official repair center.
I wish you luck.
