Sony Xperia 5 II Search bar is strange
profile.country.SE.title
Eban65
I have a strange search bar.
I made a screen capture video and took a picture from it, of topic question, can you make a screen copy of the home screen in an android phone?
As you see in the bottom the search widget is square and not with the Google G.
Just the word Sök, Swedish for search.
I can add a Google search bar as you see in the middle but not place it in the bottom.
I can remove the search bar in the bottom completely from the Xperia home launcher.
But then I still can’t replace it with a Google search bar.
The square search bar just occurred a few weeks ago, before it has been the google design.
Then the Google design search bar was back for a few days but now the square one is back again.
Any ideas what to do?
Regards Stefan Holst
Eban65
I found the problem. I'm a part of the Google beta program. When I removed the Google updates the rounded corners was back.
9 REPLIES 9
Eban65
Maybe someone have an idea of an other forum to ask?
SkyNet404
Specialist
Does it still show up even when you're in safe mode?
Eban65
Thanks.
I will check with safe mode.
Eban65
No, it has the same boxy search box when safe mode start.
SkyNet404
Specialist
Did it just magically appear one day? Or did it show after you installed a specific app/service? Or change something in the settings?
Eban65
Maybe I was not paying attention directly when the change appeared. But I don't think I did any change or installing any new apps. In the launcher I can remove the search box from the start screen but I can't replace it with a widget. So that do not help. It's not a big problem because all the functionality is there anyway. But it's interesting to know if it a common problem or just my device.
Eban65
For the off topic question. I solved the problem to make a picture of the start screen by asking the assistant to make a screen shot.
Eban65
SkyNet404
Specialist
Oh so that was it! Glad to know it's working now though XD
