2015 Bravia Android TV Issues
NickCo1979
6,373 REPLIES 6,373
scottryan10
Hi all,
I have just come off the phone from Sony, and the Android TV's are to get a set of downloads next week, and they will start Monday. So by friday, we should all have working TV's with no issues.
Sony DO know of the problems they have, and i have said for them to collect the TV on Monday ( or to arrange it as they are closed now ??) Then they can supply me a model, same as my other Sony i have, KDL-55W955B which works all ok, and it does not have problems.
He started to mention a goodwill gesture to me...and i said that i have already invested just under 160 in the Anroid model in 3D glasses and 5yr warranty.....So i will want that back..!
He is calling me back on Monday, so i will update you with what is said......
Have a good weekend all....
alellio01
I think Sony CRO (uk side) are doing there best, they are also in the same situation as us, waitting for the techies who right the software.
I think its about time they broke into the PS4 storeroom.
hankmarvin107
I do know other brands also have issues.  maybe not as much as Sony right now, but after a  few updates it should be stable.
nickbaker66
How do you switch off simulated sound off
UnoBorg
Smart tv app voice does work just use voice at bottom left of app
UnoBorg
The EPG for satelite is scrambled but oviousely digital areal works fine for guide..If not just use the Android Tv app guide
UnoBorg
I use Netflix through Blu-ray player that came free with TV & 5.1 works fine
Chocohoops
Hi, if your talking about simulated surround effect, because i only use tv speakers, you can either switch off clear audio+ or turn the setting down under advanced options, both found under sound settings. I usually access this while watching TV from the action menu.
I hope it helps
nickbaker66
Thanks a lot mate I'll give that a go
Chocohoops
Hey, has anyone seen todays update come through yet?
