Netflix unable to play 4k - Sony Android
102091101
I have a fibre line with low latency and jitter and content played perfectly up until a few days ago. (watched the entire series of dare devil in 4k)
Netflix support essentially made me power everything down, discharge and restart , signout of the a/c etc.
HD content plays without problem and 4k content on youtube has no issues playing.
If I kick off a 4k episode now, it plays for a few seconds , buffers and then only plays audio.
I notice that the recommendations are taking longer to load than usual at the moment as well.
Anybody else experiencing similar behaviour?
102091101
A broadband speed check is fine.....as implied by my initial post. I fixed this by going into netflix setting -> choosing "get help" and "check your network" , after that check, content played ok - just posting in case anybody comes across the same issue.
2 REPLIES 2
Anonymous
Not applicable
Hi there
When you are having problems, goto www.speedtest.net and see what your speed is?  it is entirely possible this is a line or ISP related problem.
102091101
