My Xperia L cpu temperature gets upto 70 degree celcius if i play some games..Is this normal. If not what is a safe cpu teperature?
Please follow my instructions as per the above as this needs to be looked at sooner rather than latter.
Don't forget to mark posts that answers the topic as Accepted Solution.
If you find any post helpful, press Kudos.
What are your thoughts about this forum? Let us know by doing this short survey.
Hi I have purchased xperia L 10 days back and from the first day i felt the phone gets heated within a minute when i started using the phone not only in calls generally when i operate the phone the phone gets heated please advise to resolve this
Thanks
Mahendran
Try a factory reset. If it does not resolve your issue, take it to a Sony service center.
You can get the nearest service center by going to this link http://sonymobile.servicetrack.in/
Don`t worry , its quite normal...:smileyhappy:
Sorry its not normal my phone gets heated abnormal..
The phone will actually shut down if it gets too hot. Heating itself is quite normal as the processor will generate heat when in use but is yours getting so hot that it shuts down?
If it is behaving like that I would strongly advise returning the phone so that it may be assessed by an authorised repair agent.
