Xperia L heating
ST91
Xperia L heating
My Xperia L cpu temperature gets upto 70 degree celcius if i play some games..Is this normal. If not what is a safe cpu teperature?
Tags (1)
35 REPLIES 35
AnandSRM
When I play games for sometime,the phone is getting heated to such an extent that I can't place the phone to my ear for a call.Sometimes its getting heated while being on a call for, say half an hour.Any suggestions,to cool down my phone..??
profile.country.RO.title
_alexdon_
Yes,stop using task killers,battery savers,try to disable some of the phone functions like wifi,data when you do not need them.Also,syncing stresses the phone.
alexdon
xperia-nce
Ive found that the device heats up quite a bit when i have my hand against the back cover, heat transferring from my hand to the device... So i started holding the device in a different way, holding it by the sides with my fingers rather than resting it on the palm of my hand, this seems to help ...
_alexdon_
Of course,especially when the phone is intensely used and if you have a back cover.When the phone is very hot,even the battery does not charge.
alexdon
Dibs20
I am too facing similar issues. and my handset is also less than a year old.
The service center said thay will not request for replacement as  its not a part of the agreement. The customer care said rest and transfer data. As per service center people, replacement is never done . they can onnly change spares even if the handset does not have a physical damage.   I strongly recommend. This would spoil sony brand image
Sylaa
Hi, can you advise me on what to do to minimize the too much heating of my phone?
