Battery draining too fast
asuchow
In one one hours it takes away 20-25% of charge. Its drains to.faast. I had reset factory data still facing problems. What should I do? Just 1yr old phone.
4 REPLIES 4
Uliwooly
@asuchow
check what's draining the battery and also test it in >>> safe mode
CameronT
Champion
Hi @asuchow,
Welcome to the community.
Please do what @uliwooly suggests, you can find the information under Settings > Battery > Show battery usage.
asuchow
Tested. Still it is draining. In 1hour its taking 20% charge.. Service Centre says its cause of jio Sim card. But previously I used to use jio Sim that time it was good with the battery!
CameronT
Champion
@asuchow,
If it is still doing the same thing in safe mode then try running a software repair using Xperia Companion.
