- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hello! I have a Xperia M4 Aqua, since i buy i see in the afternoon and the night that the screen of the cellphone show's very clear the preview picture before you take the shot with the front camera, but when you take the picture the final result is a very dark picture, if i take a snapshot in the screen i see clear the picture, but when i take is too dark!... Did any one has the same problem?
I aprecciate your help. Thank You!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Try clearing data of your camera:
- Go to Settings -> Apps -> All -> Camera -> Clear data and restart your phone.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
when shooting in low light it helps to have a steady hands or a tripod
try to change your settings to manual then night scene or increase your exposure settings,
if you are using supperior auto make sure it detects the scene correctly, and also enable your flash
can you show some samples you have taken?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I got my Sony experia m4 a few days ago and it was fine until last night. I I put it on charge and left for at least an hour and when I went to turn it on and use it, but so I press the power button and everything was fine and it go to the animated blue screen and it just stayed on that screen and I have tried unplugging the charger and then charging it again but nothing has changed plz tell me what is wrong, but why it's doing this and I can fix it
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Well i take a few shot's and it looks that the camera is really crazy, it make somethimes works fine and the preview is bad and then the picture is good, then in other times the preview is good and the picture gone wrong! like magic i try to take a picture with this problem and it gone!... I will wait if this problem appear again, thank you for your solution!
@nolramlb wrote:when shooting in low light it helps to have a steady hands or a tripod
try to change your settings to manual then night scene or increase your exposure settings,if you are using supperior auto make sure it detects the scene correctly, and also enable your flash
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
