Marshmallow update storage space
NoisyStorm
I am just wondering just how large is the marshmallow update?
I checked on DiskUsage that the android system used up ~6gb, plus the 3~4gb reserved for the system, does it means that almost 10gb of my internal storage is used up for marshmallow? If it's true it's quite ridiculous.
ppgsk17
Around 5.11GB should be used by MarshMallow upgrade, rest akll should be user usable. Check if you have cache data in GBs and try clearing it.
2 REPLIES 2
ppgsk17
Not applicable
How i saw in C5 Ultra Dual, it's must be similar Lollipop - around 4-5 GB Slightly_smiling_Face Marhsmallow for C5 Ultra Dual is the same like Lolipop or around that Slightly_smiling_Face For different markets is different size Slightly_smiling_Face In XperiFirm you can compare size of firmware in different markets Slightly_smiling_Face
