I recently bought me the xperia M4 aqua dual and configured the Myxperia service on the device. After day 3 I restarted the M4.
As the M4 was started up the MXTP gave me the lockdown screen with the verify, wifi settings and emergency call options on it. So as I wanted to unlock my device i pressed the verify button and a log in screen for my google account appears. I use my google account on all kinds of different devices so I logged in. But here someting goes wrong.
When I typed in the username and password to verify it is my M4 it gave me a loading icon for 2 seconds and then it says "incorrect username and/or password" and my M4 stays locked. To double check if my password and username are correct i logged in to another adroid device and my laptop with no problems. So now I'm stuck with a brand new non working xperia M4 and my hope for a good working security system is all lost.
Thanks Sony.
How did you do that?
Hey everyone, I had the same trouble described 3 days ago with my Sony Xpera M4 Aqua and I just managed to unblock it thru Sony PC Companion. I contacted the Tech Support online and they just sent me an e-mail describing step by step what you have todo and be careful about. They mentioned that this problem of blocking the cell phone and not accepting credentials was due to a bug but it has been solved thru a software update. The indications are in Spanish (my native language) so I just translated them as I was sent, sorry if I'm not clear enough.
Para hacer una reparación de software usando una computadora con Windows (To make a software repair using a PC with Windows)
I followed the steps carefully and it works. I hope I can help somebody
Regards.
IT WORKED IT WORKED IT WORKED!! my C4, yes my C4 runs smoothly, flawlessly, its fast and wifi works and everything!! thank you sooo much!! now i dont have to try to send it to sony to get it repaired! i can use my awesome c4 again!! thanks a ton!! it never worked before with pcc but that method worked! spread the word everyone!
when the update finshed, phone finished turnign on 10 minutes after i turned it on, mxtp lock screen came up, put wifi on, entered my google credentials, phone all of a sudden restarted and it works normally now!
my phone is not authenticating i tried many times loging into it with the correct password in is not working
what should i do now???
Pleased help me my xperia M4 aqua i'm lost password authenticate xperia please help how fix solved this serial
Do exactly what's posted on this page.that long post. I did it, it worked. Just don't forget to keep volume button pressed down when you attach phone to the wire. Good luck!
hi,
I did exactly this and it was successfully updated but I still can't authenticate my xperia. I changed google password before I reset my phone to factory settings. Android has this new protection thing that one won't be able to access google account in 72 hours after resetting it. Is it possible that this could be the culprit why I still can't authenticate Xperia M4 Auqa?
Thank you very much.
mxtp
My in Iran
Help help
IMEI:
Thank you so much! That worked for my Xperia Z4 Tablet. You are awesome x 10.
Hello my phone is protected. I do not remember a gmail account and password you were given. I do not know what to do
