@Zizolec But where did you get the information about xperias being limited to 1A at charging? EP880 and EP881 have 1500 mA output and work with all xperias.
@Alvyibnferoz You can safely use another charger, with higher amperage.
Yes, you can use a charger that delivers a higher amperage and it should charge faster. Remember to try and use original sony chargers for best charging experience.
I don't think so . Sony phone itself have a circuit to regulate the input amperage. normal AMP for Xperia is 850mA, maby it will charge with max 1A.
If so then it really. It's too low for a phone at this price.
I have Xperia M5, in my observation huge difference in charging depends on cable. If i use normal usb cable 80% takes up to 6-7H, on orginal cable it kaes about 2 H.
Yo can try app'k like
Ampere or Charger Tester (ampere meter)
