Will charge faster if i use a 5v 2A charge?
Alvyibnferoz
Charging time with the charge that was in the box (5V 850mA) is very slow and takes almost 4 hours which is very annoying. So if i use a charger with 5V 2A will the device charge faster? It is supported?
18 REPLIES 18
icstm
I am never sure why there is so much uncertainty about these things:
CURRENT - MAX defined by the charger ACTUAL defined by device
VOLTAGE - MAX & ACTUAL defined by the charger
With some devices, the most common being Snapdragon phones, they can request the charger supply a higher voltage for quicker charging, but BOTH THE PHONE AND CHARGER NEED TO BE COMPATIBLE.
In this case the charger changes its voltage.
In any case, with a 5V charger, your phone will pull what it can.
There is no spec given, however from my experience of different chargers, I would say about 1A is the max for our phones.
Remember that if your phone is ON it is probably pulling 100-200mA so it has a material effect on charging speed.
As others have said, branded chargers are best.
Not because they are faster, but they provide a much cleaner 5V signal. Cheap chargers can damage your device as their voltage variation can be huge, even on a small 800mA load.
JasonNath
Hi how can I make my battery charge faster? It usually takes 2 hours from the charger & 4 hours from a pc usb port. The battery drains fast when using wifi or mobile data. Is it safe to use an iPad charger?
icstm
You probably cannot use a iPad charge, as it is not USB so will not fit, even with an adapter, and the voltage will be different.
HOWEVER FOR FASTER CHARGING WE HAVE HOPE:
Our MediaTek X10 chip supports their equivilant of FastCharging by Qualcomm:
http://www.mediatek.com/en/features/power-management/pump-express/
JasonNath
Hi I have tried charging with an iPad 12W USB Power Adapter & it works!, charge time is only around 1 Hour! so far I have no issues with the phone at all.
icstm
Sorry I see what you mean, a charger but with a standard USB port which happens to be supplied by apple.
Yes, that charger is 5V (well 5.2V) so yes it would work fine.
Alvyibnferoz
Looks like it does charge a lot faster with 5v 2A charger. Even my old xpera P had 1.5A charger. Why sony included only 850mA charger with this phone? Expressionless_Face Using old xperia P charger, charges the phone a lot faster Slightly_smiling_Face
icstm
technically the faster you charge, the fewer charges the phone battery will maintain full capacity.
msquare
I have sony M5.. it takes 4 hours to full charge.. If I'll apply high ampearage charger.. will it harm my phone's battery or my device?
icstm
The supplied charger is very underpowered. You should have no worries using a 1A charger and the odd charge on a 2A model is also ok.
