Xperia M5 not updating to marshmallow
dx1
I recently tried to update my xperia M5 device to marshmallow through pc companion, the update was downloaded but when I connected my device through the cable then a messge appeared on the screen of my device which read that ''Unfortunately, update service has stopped''. Hence, I just couldn't update my device.
41 REPLIES 41
JasonNath
You have to wait a while longer, also when that happens just tap ok and then the Xperia Companion will tell you what to do next .
juliojose
Connect the Xperia M5 to pc companion after download the updated software it require you to turn off the device and disconnect the phone to USB. Just restart the device while holding the down volume do not disconnect the usb cable this is to be able to continue updating the device.
dx1
Tried this method as well but still the same problem persists. Now the thing I'm looking forward is for the ota update to arrive.
dx1
When will the marshmallow update be available for Xperia M5 dual via ota?
Noorey
Trying to update my Xperia M5 Dual from Xperia Companion. But everytime getting the same error. Any solution for this? It says internet problem but my connection is fine. I am unable to download the software update
toshiimsa
error code: uegetphoneinfofailure
ue_1200
anyone knows why this happens whille updating to marshmallow via pc companion
toshiimsa
Fixed need Internet connection
Rlvelasco
The software is downloaded but when i try to install, it says cannot be update.
Thelastofus
Connect to internet And retry installing update!
Uliwooly
@Rlvelasco
Try again with XC
Xperia Companion (XC)
Software Repair Guide
http://talk.sonymobile.com/thread/36355
