(Android 8.0 Oreo bug) XF9005 reboot automatically when turn on the TV in Oreo update
wuyuankai
Hi
I updated my TV to Oreo, it's working fine except that after a long period of standing by, when I turn the TV on, it will show the Home Screen for 1 sec, then it reboots it self, it shows Sony logo then Android logo animation, it taks 1 min or so to boot.
If I hit power to go to standby and turn it back on again, or in a short amount of time, it won't reboot itself, I only notice this after a long period of time of stand by, e.g. turn on TV next day, it will go to this boot cycle.
My setup:
XF9005 on Oreo V6.5830 android, connect Sonos Beam with ARC, connected to internet by Wifi
Sony could you confirm if this is a known bug in the update?
195 REPLIES 195
profile.country.IT.title
Marino.Manolo
Try disconnecting the TV from Wi-Fi and check if it is still restarting.
Manolo
wuyuankai
I disabled the wifi, also turned off the Built-in wifi, the issue seems resolved.
However I had trouble enabling the wifi again, I can't enable the wifi as well as the "built-in" wifi options in the setting, then I tried reboot my TV the issue is solved.
I need to test to see if the TV will reboot again when I turn on while the Wifi is connected to the Internet, as I can't turn off the wifi everytime right?  Time will see, I will report back here if this is actually solved or problem remains.
Will keep you posted. thanks
Vanilla_
Contributor
Hi wuyuankai,
It seems weird that the issue is solved by disabling the wifi on your TV. I think if that's the case, it won't be really convenient to do this as a workaround. But I might have a solution for you. Are you using any VPN services to access the internet? If yes, you can try to disable them and test.  Let us know the updates.
Vanilla_
CELIYATISO
@Win_88 wrote:
Hi wuyuankai
This seems like a minor glitch that can be fixed by some basic steps (hopefully):
Vidmate  iTunes Notepad++
  1. Go to Settings - Storage and reset - Internal storage - Cache - Clear cache
  2. Unplug the TV from the mains for a minute then plug it back in again.
I'd recommend doing these to steps every now and then to refresh the TV (even if nothing is going wrong).
Win_88
CELIYATISO
@Win_88 wrote:
Hi wuyuankai
This seems like a minor glitch  FileZilla  Malwarebytes  Rufusthat can be fixed by some basic steps (hopefully):
Win_88
wuyuankai
Hi
No I don't use VPN.
Also after weekend, it seems the issue has been resolved, even I have turn on my Wifi, doesn't reboot when i turn on.  It looks like By turning on/off wifi, also turn on/off "Built in wifi" may have reset the network settings somehow and resolve the issue.  I will observe over this week to see if it happen again, will update in this thread.
wuyuankai
Try go to Settings, then find Wifi settings, turn off Wifi, and also find "Built-in Wifi" settings, turn that off as well.
Long press the power button on the remote to reboot your TV,  turn on back "Wifi" and "Built-in Wifi", you may need to re-select Wifi hotspot to rejoin the internet, see if that happens again, it seems this solves for me.
Tenneen9000
Hi CELIYATISO,
Can you let us know how's your TV after trying the steps suggested by wuyuankai?
Cheers,
Tenneen9000
ngeorgieff
The Wifi workaround worked for 2 days and then my TV started rebooting again.
wuyuankai
Update
So after few days observation, the reboot bug seems gone after the Wifi "treatment", however, I do notice abour 2-3 times it's cold boot when I turn the TV on (after a long period),  it means that the TV system was probably crashed already when it's in Standby mode, when I turn the TV on, it shows Android, Sony logo straightaway, means it wasn't in Sleep mode.
