- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
August 2016
August 2016
Hi, my Xperia M2 Aqua regularly tells me that memory is 75% full and that I should transfer to SD card. I do this but in a few days I get the message again.
In my previous Android I could dial *#9900# and get to the Sysdump menu, which allowed me to free up a lot of memory. How do I do this on the Xperia M2. ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
August 2016
August 2016
Even if you move apps to your external SD card, their data is most likely stored in internal memory. Also, there is no usage on xperia for that code, but you can clear cache for your entire device under settings - storage.
alexdon
2 REPLIES 2
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
August 2016
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
August 2016
August 2016
I would suggest uninstalling unimportant apps or apps that you don't use. disable apps that are not frequently in use.
or perform a software repair using Xperia Companion. then choosing carefully what apps you need to install.
