Even if you move apps to your external SD card, their data is most likely stored in internal memory. Also, there is no usage on xperia for that code, but you can clear cache for your entire device under settings - storage.
I would suggest uninstalling unimportant apps or apps that you don't use. disable apps that are not frequently in use.
or perform a software repair using Xperia Companion. then choosing carefully what apps you need to install.
