WiFi turning it's self off straight away
itsbricked
Hello, earlier today my phone's WiFi started turning it's self off as soon as I turned it on. I have since restarted it several times and the problem is still there.
Does anyone know how to fix this?
Tags (1)
profile.country.FI.title
coolaarne
Try uninstalling android wear software and then check the wifi.. did wifi start workin?  if it did, would you care contacting sony and scream "fix it ASAP"? Slightly_smiling_Face
14 REPLIES 14
Uliwooly
Settings > about phone > diagnostics > test > test WiFi
itsbricked
It passes the WiFi test as the WiFi will turn on, it just turns straight back of again.
Uliwooly
Test it in safe mode
itsbricked
I have and that made no difference.
I have contacted a sony support member and been told that it will have to be sent in for repair. Does anyone know how to get in touch with the escalations team as it is a phone I have had for only about a month after being a replacment for a phone that over a 3 month (roughly the same time as I had had the phone before that) period was "repaired" multiple times, which after each it had new problems.
coolaarne
Hi, I have the same issue. First the factory reset fixed the issue, but right after i installed android wear + motorola connect smart watch apps, the Wifi issue started. After starting wifi, it turns itself off immediately.... So I guess the wifi issues has something to do with android wear....
Do you also have android wear?
coolaarne
And after uninstalling the android wear things from the phone.. TADAA.. wifi started working..
God i miss my old good Jolla phone, which i accidently broke:D
itsbricked
I did have android wear, though this isn't sounding great, after spending money on a SmartWatch
itsbricked
Just did the same and viola
coolaarne
